Garmin 430 enter button repair
Kahuna
Moderatoring
My 430 enter button is flaking out.
Garmins flat rate fee to repair a button is insane.
I have experience with boards and switches.
Does anyone have experience repairing these buttons?
The unit is getting useless if I cant get past this enter button madness.
Would it be save to "assume" the button is physically ok but pushing it does nothing?
Face of the Button physically there and fine. Over the past year I have to push it harder and harder to get it to work. Now getting to where no matter how hard I push, sometimes it wont work.
I do not know whats behind the button. I would guess some commercially available button but Ive not had it apart. Im not afraid to take it apart (did that to replace the battery). Ive got experience with board level soldering and desoldering if I knew what was behind it I could order one and repair it myself.
I've "repaired" a few intermittent/inop button on Garmin units by spraying some "deox" behind the board where the button makes contact with the sensor board. These are resistive type switches and "cleaning the contacts" seems to fix most of them.
The problem I've seen in the Garmin transponders is access, the keypads are not readily dissassembled so applying a surface treatment directly, from what I've seen, is not possible.
Repair Update
I removed the unit, put her on the bench, and took apart the face plate. Nothing too complicated.
Got the board on the bench and located the offending button. These buttons reminded me of my Atari game joystick controllers. Only those things button would go flat. My offending button had positive actuation feel. Just poor contact.
There is a film protecting the buttons. I lifted the film, the buttons are only held in by the plastic film. I carefully lifted the metal of the button and sprayed the bejesus out of it with some MAF sensor cleaner I had on hand. Phillips screwdriver shows the lifted film.
Reassembled and it is back working and mostly effective. Still not making contact like a new button. But does work much better and this helped. Still requires a little extra push but does not require the smash of before.
It comes apart easy enough that if it happens again Ill try another solvent.
If you have to do it again, try this...
http://www.all-spec.com/products/D5S-6.html
I use it all the time to rejuvinate contacts on vintage Hi-Fi stereo equipment, and I used it to clean a couple of buttons on my GMA-340 audio panel. It works amazingly well in applications like this.
Part/most of the problem is oxidization of the contacts, and Deoxit will deoxidize as well as clean them.
Kahuna,
I've had the sprung/disc slip out of position. Good tape is a must.
The other concern is the shape and integrity of the back side of the button. If it's deformed, a little prc sculpting has been known to work.
Good luck,
interesting post. i have a few difficult buttons on my 430 that have been the same for quite a while. i will give this a try some day. seems like corrosion x would be a good candidate to help get the buttons going again. thanks.
Good job Mike,
Folks are a little shy to take this stuff apart for a button fix, glad you took the the bull by the horns, somehow I knew you would :). I've done this a few times and its not much different than your basic TV remote. I'm more aggressive and use 1000 grit to clean things up :eek: :D but I get it the first time.
An update to this old thread for people who, like me, get queasy about opening up avionics to fix sticky buttons:
Bevan Aviation in Wichita will refurbish a 430 or 530 (including buttons, memory battery, software update, etc.) for less than half the $1,868 that Garmin charges as a "flat fee" to work on these units. (Note Garmin alternatively charges a lovely $500 "assessment fee" if it turns out your unit is not repairable.)
I sought Bevan out after my 430W's buttons became so far gone that the classic sticky-button technique (pressing them repeatedly for 20 minutes...) wasn't bringing them back to life. My unit got entirely new buttons, software update, comprehensive testing, and a new memory battery, and is now working perfectly. Very happy with Bevan's service.
I suspect that Bevan, like Garmin, may no longer have access to replacement 430 display modules, but who knows. I was intrigued to learn that the screen part that breaks or gets messed up the most, which is the clear plastic in front of the display module, is still available.
With any luck, I'll get a second 17 years out of my 430. Such a hugely cost-effective gadget, especially when you consider what Garmin wants for a replacement IFR GPS/Navcomm. I was encouraged to see recently that Garmin intends to support the 430 and 530 for "decades." Should keep the resale value up.
I've got the same problem and probably going to go with Bevan as well. Can you share what the cost was?
I had my 430W buttons repaired by Avionics Unlimited at KCXO a couple years ago. It was a couple hundred bucks I think. Behind the rubber membrane are what he referred to as "snap caps" which are standard electronic parts. You just have to know the p/n. Worked like new afterward.
A little over $900 for the refurb, including insured shipping both ways. The replaced parts were the buttons and battery, might be more if they have to replace something else.
I swear the radio sounds better—either they tuned it up somehow, or I made a better connection when I reinstalled it. 🤣
I was thrilled to learn that the settings were preserved. I took photos of all the setup pages just in case.
