AS I wrote a couple of weeks ago, I was totally blown away with the XM weather on a Garmin 396 that a friend loaned me for a trip. By my estimation, adding XM weather to a capable airplane is probably the single biggest enhancement to using a GA airplane for travel since the invention of the wing...
(It was also mentioned that I was a hopeless technology addict...well, that may be, but I'll let you know that I have passed on the "Popeil Pocket Nuclear Reactor"...and have put all thoughts of the Ronco Flux Capacitor of my mind....probably wouldn't work with my food processor anyway...)
Anyway, I called GRT to order their XM weather box, so that I could add the weather directly to my EFIS, but alas, they are currently doing some re-engineering, and delivery is on hold. I had them add my name to the waiting list, and went to eBay to find a used 396...which I got from a good avionics shop at a great price!
The only problem that I faced was finding a place to put it in my admittedly already full panel. I took great care in designing an integrate cockpit with everything just where I wanted it - so adding an additional box was a challenge. Several friends contributed good ideas for using a RAM mount attached to the roll-bar reinforcing triangle - and that would have been good, except it would block my view to my other avionics. So I engineered it the old fashioned way - by sitting in the cockpit and moving the box around until I found the right spot. I then attached a RAM mount base to hold it there, and voil? - a nice solution!
The ball of the RAM mount is attached with four screws to Rivnuts on the F-804 cover. I was impressed at how sturdy the RAM mount is! Having the 396 in this spot makes it very easy to operate with my right hand - sort of like a keypad on a center console would be from a left seat. I was surprised that there is no interference with my flying hand (right) as my elbow is behind the 396. If it ever did get get in the way, I can swing the 396 straight back, down into the passenger foot well. The antennas and cables are just velcroed in place, so nothing is permanent, and I can use the system elsewhere, or remove it when I get the GRT Wx box.
I'm sure that everyone's solution will depend on how they have laid out their panel - just thought I'd share this one, as I hadn't seen it before.
Paul
![396mountnw9.jpg](/proxy.php?image=http%3A%2F%2Fimg526.imageshack.us%2Fimg526%2F8461%2F396mountnw9.jpg&hash=50843e4ff94340890d7c8b57f25ecadf)
Paul
