RidiculousM
I would like to mount my GEA 24 EIS interface to the left of the VPX on the bulkhead and have the engine monitoring wiring go straight through the bulkhead and through the firewall so it would be entering the engine compartment just above the engine mount and a little to the right of the upper left engine mount bolt. I do not have my engine mounted so I am looking for advice if this is a good route to take or if there is a better suggestion on where the wiring should enter the firewall. The engine will be an IO-360.
