OK, this is probably a really stupid question, but here goes...
I have the Champion gap tool with wires marked as .015, .018, .019 and .022.
So...how do you set the gap for *.016*? That is, from everything I can discern, the smallest allowable gap for the plugs.
FWIW, I gapped mine to .018 (.018 wire passes through barely, some slight resistance, .019 does not), which is well within the allowable range. But I'd like to gap them smaller if that is, according to conventional wisdom, better.
