I rolled my elevator leading edge and pop riveted it. It looked real nice from outside. (Picture below). However, when look at inside, there is gap between the top and bottom halves. It looks like the pop rivets didn't pull the two halves enough to close the gap. When the two halves are clecoed, there is no gap. My questions are:
1) Is this gap acceptable because this is low load area? My concern is more for vibration. Anyone with flying RV and gaped leading edge experienced something bad?
2) The aluminum pop rivets are easy to drill out, so I can re-do the riveting. Any tip on how to close the gap when pop riveting it? Or do I have to mess around the bend to make them perfectly match without much applied force (e.g. match without clecoing them together)?
Thanks!
Thanks!
![30109jn.jpg](/proxy.php?image=http%3A%2F%2Fi51.tinypic.com%2F30109jn.jpg&hash=5ef1770fd65a1dfc4f672ad7faa92b93)
