Fearless
Builders and Flyers,
I got about a 1/32 gap between my leading edge and tank skin. The rivet and screw attachment holes in the main spar are lining up for the leading edge and tank where I have clecos in place. Is the gap a problem or will I be okay with it. I'm not sure I can get it closed up any tighter. Is this a case where it is good enough or do I need to be more anal about the fit.
