Gap between 903 & 904
jlfernan
I just clecoed together the left HS. At the joint between the 904 rib and the 903 spar inboard(the angled rib) there is a gap. I have the 909 spacer in place and all the other holes line up. I can pull it together, but then the flange on the rib is not square. Would it be OK to make another spacer to fill the gap? The link below takes you to a picture of the problem.
Jorge Fernandez
N214JL(Reserved)
7661
