I am installing the aileron push rod connections and wonder if there is a concern for galvanic corrosion in the steel bracket/brass bushing/steel AN bolt joint? Seems like it would be an ideal location. Would appropriate grease help prevent it or would it just make a fine electrolyte in the joints? Is there a good choice of grease here?
