I started with manual but changed it to auto after my first night flight.
You don’t want to have to remember to switch off the wig wag at 100’
Which is about where I noticed it.
I have the airspeed set at 85kts.
Mine is set to manual, mainly I don't necessarily need it to be on when I am up high and also, if I understood it right, it will not come on during landing. I want my wigwag on during take off and landing during the day.
My 10 panel did the same as 14 but should not have. Could have saved some switch space. When I depart (day or night) turn on taxi, landing and wig-wag. Landing the same. Why have 3 switches when only 1 needed? Is it bad form to have landing lights on when you are taxiing? Strobes a different story, please turn off while taxiing. Aveo wig-wags uses taxi lights by the way.
Auto, then it is a non brainer and one less switch, or switch function, on the panel. What do i have it set for? Good question, I should review my settings. I want it set to flap speed, so 85 kts
I’m set up for manual using a single switch (OFF-ON-ON) which is wired for OFF-ON-WW/ON.
If I decide to try out the auto function using flap speed, my assumption is the alternating flash input is ignored which makes the switch OFF-ON-ON >85 knots and OFF-WW-WW 85 knots and below.
