Electrogunner
Hopefully g3xpert is online. Need confirmation before I start depinning the d subs. I have the UMA 6 cyl mag bleed port tach sensor. The 900x manual says to use pin 15 in P701 connector which is 5v output which feeds some other sensors as well. Right now I'm using pin 16 which is 12v output, harness was made by a well known vendor that has done an excellent job. Want to confirm which output is needed as this harness is not the easiest to take apart. FYI typed this while jammed in the pilot side footwell
. Email [email protected]
![Beaming face with smiling eyes :grin: 😁](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f601.png)
