When you installed your avionics, the G3X requires you to do a calibration with the plane in a straight and level attitude... did you do the same thing for the G5? They dont share that info - you have to calibrate each individually.
in addition to the calibration, there is a manual offset for pitch indication. I just don't remember where it is in the menu structure. Look at the manual. The calibration just puts an offset in there, so it's easier to just manipulate that field.
Well, it worked. I calibrated it this evening. The pitch was set at 6.7* in the config mode of the G3X. So in the config mode of the PFD, and config mode of the G5, I could set the G5 pitch offset at 6.7* also.
