I'm just curious. At Airventure, the G3X software showed on option on whether to use an external or the internal GPS. I thought you mentioned that an update beyond 6.10 was in the works for an August 2011 release.
Is that still the case?
Please tell me this update is going to help the GTS800 to G3X screen transition!!!
It looks like the "Install Manual" Rev date changed to Sep, 2011 on the manuals download page, but the manual that downloads from that link is still the older manual. Both are Rev E.
As with all technology, the documentation is slightly behind the software. In config mode, access the display config page, press the OPTIONS softkey, and change "PFD2 layout" to "User Selected". Now, in normal mode, you can access the Display Setup page from the main menu and change "PFD2 Layout" to three different settings, one of which is "PFD/MFD" which allows the copilot to navigate between a full-screen PFD page and full-screen MFD pages.
mcb
