My GSA28 auto pilot pitch servo failed Garmin replaced it under warranty. The replacement works fine. The problem is it does not run the trim. I get a trim up or trim down command on the screen. As though I have manual trim it my RV-10.
In setup the motor trim is enabled and no GSA28 trim servos are enabled. The trim is wired through the GSA28 and the stick control works fine and in configuration the test function works fine. So the G3X can run the trim but in auto pilot mode it can not. Garmin has not gotten back to me on this. Any suggestions?
Tom Spencer
Tom Spencer
