A bit confused:
G3X Diagram on page 27-37 connections for Connext format to GNX 375 using serial in/out 2, pins 14,30,34 on P4X02.
Moving to page 27-25 shows a Vertical Power VPX also connected to serial in/out 2 on the G3X using pins 14, 44 and 30. (same in/out lines, different signal ground.
Do I simply choose another serial in/out pair and configure accordingly or have I discovered a conflict in the drawing guidelines?
I'm probably missing something in the manual (as usual) but if anyone can shed some light on this, I'd be grateful.
