I installed the latest version of system software, v4.20 from 4.1. After updating both displays, I go into config mode and check to see if all the various components / LRUs have had their updates applied as well (if applicable.) Since I normally keep the autopilot servos off, a fun thing I like to do is watch the servos get updated when I turn them on. The roll servo updated on the first try, however the pitch servo failed on several attempts. I recycled power, went into config mode and observed another failed attempt, but on the second try, it worked. I flew after that, and everything worked properly, AFA I could tell.
The question is what could be causing this, and is it anything to be concerned about? Network error is 0%. The servo is second to last on the CANBUS, and the last device (GPS 20A) on the bus works fine.
