Check your module if it is Apple compatible:
1. Activate configuration mode (press and hold the MENU key while applying power to the system).
2. Select ?System Information? page.
3. Highlight the ?PFD1? field in the device list.
4. Press the MENU key.
5. Press ?Check Apple Device Compatibility.?
6. When prompted to start the test, select ?YES.?
You should get a message "Apple Device supported" or "Apple Device Not Supported"
The G3X is only compatible with an Ipad 3 or newer, Ipad Air or newer or Ipad Mini with Retina or newer...
