marcusadolfsson
Member
Heads up on something that took me a while to realize on my G3X Touch with GDL 39R.
For a long time the NEXRAD overlay on the MAP page is very messy compared to what I see in ForeFlight, almost to the point of being unusable.
![](/proxy.php?image=https%3A%2F%2Fpreview.ibb.co%2FdePqya%2Fmap_mode.jpg&hash=f9a5e0e5ebd51792df51fdd566d4dacb)
On my last flight, I finally realized that what is happening is that the Regional High Resolution feed is being overlaid on-top of the CONUS feed (Combined mode). Ugh.
If you go into the WX page, and select Regional you will see the higher resolution feed.
![](/proxy.php?image=https%3A%2F%2Fpreview.ibb.co%2FjLPUrv%2Fwx_regional_only.jpg&hash=5e1b12056bb6912ddbb0a7a262033ca9)
I emailed G3X support to suggest that they either allow the option to toggle between Conus/Regional/Combined on the MAP page (as you can on the WX page), OR do what ForeFlight does and don't render the CONUS feed when regional is available.
