The instructions say to ground the ring terminal against the bare clean Alclad wing skin interior. I have been running ALL grounds back to the battery bus (tabs) for good practice (No airframe grounds),
My question is, if I run a ground wire to the battery bus, in addition to ring terminal under the probe, will that create a ground loop ?
