Whatever "skills" I have learned through the build must be going away...
I went to squeeze the last rivet on the G3X mounting template, and now it appears to have buckled or has local plastic deformation because now the mounting screen is not completely flush with the backside of the instrument panel.
As you can see, it's only on the top there where it bulges out. I'm not so worried about the structural capability since it's just a framed outline with nutplates in the corners, but I don't want that thing vibrating around and screwing with the display unit.
I'd like to avoid drilling and riveting a few holes to make it sit flush again.
My brainstorming options:
1) leave as is and don't wory
2) rivet in 3 places to make it sit flush
3) use adhesive? and clamp until cures.
Any thoughts?
![20140728_185438.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-COMd2vlc8JU%2FU9cCVLbXbXI%2FAAAAAAAAFLc%2FYvV0aUSPAHQ%2Fs640%2F20140728_185438.jpg&hash=7ec150ffc5d3873747818bbe052f9cde)
Any thoughts?
