machineman
Member
Hi All,
I am having a problem with a couple engine sensor indications...
This is an IO-360 that has just had it's initial engine start....
With engine off, I am getting the following
Fuel pressure 4.4 psi
Oil Pressure 10 psi
My fuel pressure indication appears to be wrong also?
I am getting 39psi of fuel pressure at 1500rpm
(Mahlon at Mattituck tells me I should be seeing 18-25 psi at 1500 rpm.)
I can?t find that these sensors can be calibrated in the G3x...
Has anyone experienced this?
Rich
Oil Pressure 10 psi
Rich
