With the Garmin systems, what cool things can you do with a switch/button ... thinking about panel buttons and stick buttons.
Great thread. Some input on the questions/comments:
- Some other cool things you can do with a separate external switch. You can make your own button for level mode. And you can use a separate switch to arm/disarm our electronic stability protection (ESP-X) functionality. They just require use of one of the configurable discrete inputs.
Brian, can you elaborate on where the discrete inputs are? As I recall, there are more than on “box” which can provide them.
Brian, you said:
Will the G3x, the GAD27, or the GEA 24 provide speed-selectable limits on trim speed, like the Safety Trim system Van's sells? I understand that is important and I am currently determining just how broke Stein is going to make me . . .
Although I am a long way from flying with such a system, it strikes me that a function that would allow switching through MFD screens or toggling between split and full screen from a stick switch would be very handy. Can't find any evidence that this is possible though.
