G3X Configuration Question
9GT
Patron
I have my G3X three display panel in my 10 wired up and running and need to configure the EMS sensor parameters. Can anyone help me with these? I need to program the color bands and warnings for the EGT's and CHT's. I found a max limit of 435* on the CHT but thats about the only figure etched in stone in the Lycoming operators manual for the IO-540 V4A5. I've no previous experience flying behind an EMS so have I no idea where to put the settings at. Thanks for any help!:eek:
[FONT=&quot]Here are the markings for my G3X system as shown out in my POH.
[/FONT]
[FONT=&quot]2.3 Airspeed Indicator Markings[/FONT]
[FONT=&quot]Marking KIAS[/FONT]
[FONT=&quot]Red Range 200 kias[/FONT]
[FONT=&quot]Yellow Arc 155 to 200 kias[/FONT]
[FONT=&quot]Green Arc 60 to 155 kias[/FONT]
[FONT=&quot]White Arc 48 to 87 kias[/FONT]
[FONT=&quot]2.4 Power Plant Limitations[/FONT]
[FONT=&quot]Engine YIO-540D4A5 [/FONT]
[FONT=&quot] Max Horsepower 260 hp[/FONT]
[FONT=&quot] Max RPM 2700[/FONT]
[FONT=&quot] Max Manifold Pressure Full Throttle[/FONT]
[FONT=&quot] Max CHT 500 F[/FONT]
[FONT=&quot] Max Oil Temp 245 F[/FONT]
[FONT=&quot] Oil Pressure 25 psi at idle, 115 psi at start up[/FONT]
[FONT=&quot] Fuel Pressure 14 min to 45 max psi, 12psi @ idle[/FONT]
[FONT=&quot]2.5 Power Plant Markings[/FONT]
[FONT=&quot] Tachometer[/FONT]
[FONT=&quot] Green Range 0 ? 2700 RPM[/FONT]
[FONT=&quot] Red Range 2700 RPM[/FONT]
[FONT=&quot] Oil Temperature[/FONT]
[FONT=&quot] White Range 50 ? 165 F[/FONT]
[FONT=&quot] Green Range 165 ? 200 F[/FONT]
[FONT=&quot] Yellow Range 200 ? 235 F[/FONT]
[FONT=&quot] Red Range 235 ? 260 F[/FONT]
[FONT=&quot] Oil Pressure[/FONT]
[FONT=&quot] Red Range 0 ? 25 PSI[/FONT]
[FONT=&quot] Yellow Range 25 ? 45 PSI[/FONT]
[FONT=&quot] Green Range 45 ? 95 PSI[/FONT]
[FONT=&quot] Yellow Rang 95 ? 115 PSI[/FONT]
[FONT=&quot] Red Range (max) 115 ? 120 PSI[/FONT]
[FONT=&quot] Fuel Pressure[/FONT]
[FONT=&quot]Red Range 0 ? 07 PSI[/FONT]
[FONT=&quot] Yellow Range 07 ? 14 PSI[/FONT]
[FONT=&quot] Green Range 14 ? 45 PSI[/FONT]
[FONT=&quot] Yellow Range 45 ? 48 PSI[/FONT]
[FONT=&quot] Red Range 48 ? 50 PSI[/FONT]
[FONT=&quot] Cylinder Head Temp[/FONT]
[FONT=&quot] Green Range 0 ? 400 F[/FONT]
[FONT=&quot] Yellow Range 400 ? 425 F[/FONT]
[FONT=&quot] Red Range 425 ? 500 F[/FONT]
Thank you Bill. This info will give me a great place to start.
Dave
