carrollcw
In the middle of wiring my G3X touch. I am to the part where it says to jump pin 27 and 10 if it is PFD 1. I understand that if you do this, the PFD will always display engine data. I am only installing a single display (for now). Can I instead tell it that it is a PFD2 or an MFD in order to avoid that limitation? I know the FAA rule, but just for discussion sake , will it work? If by making it think it is a PFD2 or an MFD, will I lose other functionality?
