I'm trying to figure out if this is a single function or two. If anyone with a G3X can help me sort it out, will be much appreciated. The Garmin wiring diagram shows a disconnect pin on each servo, to be wired together and to a momentary switch that will disconnect when closed to ground. What about the CWS function? Is that a separate function? If so, how wired? Thanks for the help.
