daveinDenver
I'm New Here
Hi all,
Well, I am sure someone has the same set up out there. I have a RV6 and am using an O360 clone from Titan with 9:1 cyclinders with a constant speed prop. I am putting the fuel injection on a verticle induction. (So basically replacing the carb with fuel injection). I will be ordering a FWF O-360 RV7 kit with the RV6 mod kit. So for those of you who have done this before, is there anything I should just delete out of the FWF kit. Like are the throttle and mixture cables brackets so different should I delete them and then measure and build own... etc. Carb heat delete? etc etc. Just looking for suggestions... Thanks In Advance .. Dave
PS Also I am wondering how the cooling has been on the RV6's with the cooler II from vans. I was thinking up stepping it up a notch.
