I'm putting in the fuel tank attach reinforcement angles and spacers on the side skin. The spacer is .125" thick as are both the aux longeron and the lower longeron which fills in the space between the skin and attach web. Now here is where I have a problem thinking ahead when I install the lower skin in between the lower longeron and the outer skin, that the outer skin at the bottom will be pushed out the thickness of the bottom skin. Now there will be a gap of the spacer which will pull the skin in when the tank attach bracket is put on. Is this accurate and ok?
Jay
Jay
