Harold Lanfear
I haven't attached the wings yet, but am trying to finish the fuel lines and need some guidance or pictures on the -8 fuel line from the fuselage to the wing.
Measuring the wing fitting and fuselage using the spar as a staring point and comparing it to the plans, it appears that the wing fitting is in line with the fuselage fuel line exit. The appears to be about a 2" gap between the wind and fuselage.
If the above is correct, what are people doing with the connection (Vans just shows a hard line with no fittings
). Has anyone used flexible hose and had the AN fitting connection on the inside of the fuselage.
Appreciate the ideas and help in advance. Harold
