macrafic
I don't have the plans with me, so may have some of the numbers wrong.
The outer line of rivet holes in the skin that goes under the seat ribs (I think this is F-776) is not a straight line; it is curved outward between the F-704 and F-705 bulkheads. There are no instructions or plans that address this particular situation.
I'm assuming that the 2 outside seat ribs that go here (I believe these are F-715 ribs) are to be bent to be able to match-drill with the skin. That is, draw a center line down the flange of the rib, then drill the rib so that the drawn centerline is showing through the skin holes.
Can anyone verify this? Thanks!
