Fuselage rotisserie
Mich48041
Friend
I made a fuselage rotisserie so that I can turn the fuselage for installing wiring or controls. Only the firewall is supported. I have to lift and turn the aft end by hand. Although I can rotate the fuselage by myself, two people would make it easier. I thought about making something similar to support the aft end, but doing so would take time that could be spent building the airplane. If a person plans to do their own painting, being able to rotate it would make painting much easier. See pictures:
https://shc5va.bay.livefilestore.com/y1p_rs--WwT4Z6yHhoU4Xkr4nr3EG_YrJeTHU8ZDos30ziJp0PG6kHtC9SCrDNSKWoFsqJkxo1N6rJ8rNhgVXE8Gw/DSCN3266.JPG
https://shc5va.bay.livefilestore.com/y1pbixJAPntI7KE3OTLRC2H3pWx-lK4pxsunkk-VcXDOM2Xy5Q2k_8WKNvqycGVcC5eCqIrEo84Mzj0JEF0fWY1Qw/DSCN3267.JPG
Joe
Harbor freight has an engine stand for $50. You can use a piece of channel or angle and mount it to the mounting plate on the stand, and then to the tail attach nut plates on the tail.
very cool Joe....beats the **** out of climbing in and out all the time like I did...had I only had a clue.
