You can wait
I asked the same question many moons ago when I was at the same stage. Others that had gone before me said to leave the firewall edge/fuselage skin undimpled for now. You will later need to fit whatever cowling attach method you choose, and if you've already dimpled those rivet holes, it makes those pieces harder to fit. The hinges or cam-lock backing plate gets riveted in with the skin. So if you riveted it now, you've have to drill them out later. And if you're concerned about it, you can dimple two thicknesses of metal at the same time.
So we waited to rivet that on my buddy's plane, and it came out just fine. A little bead of sealant on the inside where the skin & firewall meet, then we squeezed all those rivets. Looks good, no leaks or nuthin'.
