macrafic
A couple of questions regarding the fuselage (7A).
Does the front edge of the 779 tailcone go between the 778 aft bottom skin and the 708 bulkhead?
Also, on my 711 bulkhead (forward most bulkhead of the two in the tailcone), if I clecoe the 773 side skin to the forward vertical line of rivet holes, the rear line of rivet holes do not line up with the skin. At the top of the vertical line of rivet holes, the hole is about 1/4 hole off. By the time it gets to the bottom, it is nearly one full hole off. Yet, everything else lines up. What have I done wrong here?
Thanks, Perplexed!!!
