RV7Ron posted a great thread on the wing kit order. I plan to call tomorrow and adjust my wing kit order.
Are there any similar items I should add to my fuse kit?
I put the adjustment into one e-mail. Thanks everyone for the tips
ADD
Five point crotch strap anchor
Aileron spring trim system
E718 Longeron Angle 7/8/9 AA6-125x3/4x3/4x15'2" AA6-063x3/4x3/4x6' (extra angle for misc brackets)
Misc grommets of several sizes
50' roll of 3/4" conduit (for wiring)
Flop tube (1)
Deluxe fuel caps (note: credit for standard version)
Pro-seal (1 qt)
AN833-6D (extra)
AN833-4D (extra)
AT0-032X1/4X8' (Soft Al tubing)
AT0-035X3/8X6' (Soft Al tubing)
Fuel fittings for wing including extra for return fuel line
DELETE
1. Using Grove master cylinders and reservoir ?delete Matco cyls.
2. Using Bonaco brake lines ? Delete VA-118-1 brake hoses.
3. Using Andair fuel valve ? delete Van?s fuel valve (Bag 487).
4. Using Hooker harness. Add five point harness crotch strap anchor (see above)
5. Using Stein vents. No change to vent order.
