Flying Scotsman
Quick question that I couldn't find the answer to via a search...
"Preparing the Center Fuselage" p. 8-6...
One para says "Do not dimple the holes in the aft edge of the F-776 bottom center skin. They will match up with the F-706 bulkhead and F-778 bottom aft skin later..."
Got that, that makes sense...but then the very next para says
"Dimple the holes (in the skin and ribs) that will later match up with the lower aft tabs on the F-725, 726 and 727 baggage ribs."
Huh? Aside from being a nonsense statement ("dimple the holes in the ribs that will match up with the ribs"????), what exactly are they trying to say here?
Should I dimple the center bottom skin and the baggage ribs at the very aft rib location (but none of the other holes in the aft two rows of the skin, I get that)? Should I also dimple the holes in the *707 and 778* at the location of the ribs? Should I do neither, and leave them all undrilled/undimples until later?
