Functional Redundancy!
Ironflight
VAF Moderator / Line Boy
Mentor
So there we were, cruising along in good VFR over the heartland of the nation, ready to descend from 8.5K to pattern altitude at Fort Scott, KS ? needed fuel on the way to Minnesota. Like I had done thousands of times, I reached up to the right knob on my #1 Display Unit, and gave it a push to highlight the altitude preselect box ? and nothing happened. And I knew instantly that something didn?t feel right ? that little ?click? just wasn?t there?.it was mre of a squish. Hmmmm?.this is interesting ? no select capability, which means I can?t really set the altimeter quickly either.
What to do, what to do?.Oh yeah! Display Unit #2! Since the units trade information between them what you do on one is transferred to the other. I simply inverted my normal panel, putting the PFD on the bottom and was able to do all the entries that I needed ?a routine reversion to backup mode. (To tell the truth, it took a couple of minutes to think about doing it this way?.failures of this sort are so rare that there is some finite time for comprehension and cogitation!) This is what redundancy does for you, and knowing exactly how the system works when faced with a ?failure?.
Oh yeah ? the problem. Turns out that the set screw that holds the knob on to the shaft had somehow loosened up just enough to let it slide instead of grip when the knob was pushed to activate. All I need to do is find a tiny set of Allen wrenches (I think it?s a fifty thou) here in the Cities to tighten it up before heading home in a few days?.
Paul
Paul,
I'm in Lakeville, MN, here in the Twin Cities and can certainly help out in any way possible. Actually, I owe you one for helping me get my first RV ride in Pete Howell's RV-9.
Also, If you have time this weekend, you are invited to check out the progress on my RV-7 and critique my work. I'm just finishing it up prior to moving it to the airport. I'll pick you up or whatever is required.
Just PM me and I'll give you my cell number, if needed.
size is correct
Paul - You have the size correct. It's a .050 allen wrench. I only have 25 hours on my HX but have had both knobs fail in flight. I tried Lowes and HD, but neither carry the small wrench. I was able to locate one in an old school True Value mom-and-pop kind of hardware store. They were 37 cents each, so I bought 4 of them. Good thing, because I already lost 1 of them. They are tiny and hard to keep track of!
This sounds like the B-52 dreaded 7 engine approach
As mentioned in one of those F-16 pilot stories
Peter
Nice to have back ups
