I'm curious if anyone has the full complement of weather displaying on their G3X touch? Namely: "Lightning, Cloud Tops, Turbulence and Icing"
I get most weather, but for these 4 I just have a "Waiting for Data" indication. Initially Garmin support indicated this was because these fields were Bluetooth only, and indeed they were for some period of time (first released in 8.20).
However, release 8.91 indicates they are now available via the RS-232 connection (https://vansairforce.net/community/showpost.php?p=1554165&postcount=1) and confirmed with Garmin support this is the case. I've confirmed I'm on a G3X and transponder versions where it should work.
When I initially contacted Garmin, they indicated it was Bluetooth only until I pointed to the release notes. Garmin support isn't sure why it's not working other than perhaps something is wrong with the transponder, but just curious if anyone else went through this upgrade path and if it "just worked" or there were any other steps that activated it?
