Fuel Vent line Scarf-- forward or backward
yankee-flyer
Installed the fuel tank vent while adding the additional internal structure a couple of weeks ago. As I interpreted the instructions, the scarfed edge should face forward. Just saw another local -12 today who had the scarfed face toward the rear. Their reasoning was the same as mine was originally-- the forward-facing scarf would pressurize the tank. But then I decided that was the purpose of the small "air line" attached to the vent line. Scott, can you give a definitive answer-- should the "open _ edge of the vent face forward (into the airstream) or aft.
THANKS!
Wayne 120241/143WM
PS Installed the RV-7 Aileron trim and it seems to be working but the photos I shot are lousy. After more testing I'll post the best of them and a description if it's working OK.
The scarf should face forward. If it faces backward, it will induce a vacuum in the tank. You want the tank lightly pressurized.
Forward or back
Its a fair question as the KAI were not entirely clear on this point. I actually fabricated & assembled the vent lines myself just yesterday and there is just one picture that suggested the forward orientation. Second guessed myself until the positive pressure feature confirmed it.
Dumb Question - KAI
Thread drift .... I've seen many references to "the KAI" and I must admit that I have no idea what the KAI is or what the abbreviation means. :confused:
Please enlighten me. Thanks
Previous KAI Correct
And the scarf was forward on the vent of my RV6 and never had an issue, but always wondered. Thanks for the reason!
