Third flt in RV 10 two weeks ag
ver airport. Wanted to run a fuel tank dry in order to fill and calibrate. Upon switching the vans fuel valve, the engine was surging and finally failed. Did not try to restart as was in easy position to deadstick.
Upon pulling fuel valve discovered that if valve was slightly off the detent was allowing air to be pulled from empty tank. Have replaced with Andair valve which has much more positive detent position.
I don't like the Vans fuel valve in low wing airplanes. Using in a Glastar with no problems. Just relating my experience if anyone is looking for fuel valve feedback.
