Fuel valve plate - any other use for manual trim tab?
Rick_A
I'm using electric trim on my 7A, so I don't need the manual trim part on the fuel valve plate (F-983). Before I cut it off, I was wondering if anyone has mounted anything else there?
Hi,
I had some passing thought of mounting the engine primer (pump needed here in NE OH in cold weather) on the plate, but that would be a bit awkward. It is close to the fuel lines for a tap-in, etc. Have you thought about mounting any switches of your choice? Probably not a very good idea either, but just a thought.
Don
N17QB in progress
or say XM radio receiver? You'll find something to put on that tab..
I haven't cut mine off.. either XM or "backup" portable GPS are most likely candidates for that spot.
You could put your trim or flap switch there. Then you could avoid a wiring hassle to the sticks.
Roberta
Park Brake/Heater
You could put either Park Brake or Heater Knob on it.
Mine is modified as per the pic. and has the Firewall Cabin Heat Vent Shut-off, Park Brake and Hot Cold Cabin Air Mixer control on it.
Pete.
I put my Hobbs meter
there to save on panel space. You can kind of see it in this photo..
