Fuel valve bracket
tkatc
I'm at the point where I will match drill through the auxiliary longeron to locate the fuel valve bracket. The instructions are a bit vague and the search on VAF suggests that I'm on my own anyway because I'm using the andair fuel valve. Looking for more info about what I should do NOW or just leave this task for later. Location seems to be important so it matches the cover plate that will eventually be installed. Am I worrying for nothing?
I did mine before riveting the fuselage sides, much easier access that way. I used a piece of plexi with a hole drilled to match the location of the fuel line exits to help with the plumbing. Not flying yet...
