Scott Hersha
I'm ready to seal my tanks with the back baffles. Before I do that, I want to know what others are doing with the extra VA-141 flange in the inboard rib. I assume it is there because this is an RV10 part, and it is used as a return to tank fuel line for the IO-540 engine. If so, I'll just fill the hole with an AN plug. Am I right about this? Is there a reason to install a line and bulkhead fitting in this flange for possible future fuel injection systems? What have the rest of you done with this flange?
