So here's my problem. I'm just finishing the prep for my left tank. all holes are match drilled, de burred and ready to dimple. The problem Im running into is that when I dimple, the hole is becoming over sized and a 3/32 cleco will not hold the skin and rib together. I'm test fitting a rivet every so often to check for correct depth and everything looks good. This is the first I've encountered this problem to date in my project and cant explain why? When I put a cleco through the holes I have not dimpled things hold just fine, am I missing something here?
