I've been fighting the tanks for the last few days, using the "Checkoway method" and having great results. Every time I check tank to leading edge alignment I give Vans an air high 5, It's a c hair from perfect. Im just wondering if everyone else had or is having the same battles with alignment of the tank ribs to the skin? I seem to have to apply a fair amount of pressure to get everything to line up. What happens when I throw a good layer of pro seal to the mix, will I have real troubles getting things to line up? Should I spend more time getting the ribs to line up before final drilling everything?
Thanks in advance.
Trevor
Thanks in advance.
Trevor
