Wayne Gillispie
Used 2 qts proseal then brushed PR-1005-L buna-n "cherry juice" over top of all joints inside and out. Installed drain fitting, fuel outlet with AN cap, short piece of 1/4" aluminum tubing on vent fitting to connect to an electronic manometer, Van's deluxe locking fuel cap(without duct tape). Pressurized through drain valve with blow gun until reading 1.050 psi (29.06" H2O) on manometer using very low pressure 2-3 psi. It dropped back down to around 1.000 psi (27.68" H2O) after losing the heat of compression. I sprayed leak detection fluid (used in hvac business) on all rivets and joints which cooled the air inside the tank and dropped pressure down to about 0.980 psi. Found a leak at fuel cap, tightened nut inside of cap...leak fixed.
Just for fun I tested several different balloons/gloves to see what kind of pressure they exerted when filled. All balloons tested between 0.300-0.600 psi except for one...the long skinny ones you see being made into funny shapes...that one exerted 1.5 psi at full length (4'). Nitrile and latex gloves were close to balloons. Balloons would burst between 1-2 psi hence the reason for Van's recommendation.
