According to my notes from a year ago, the fuel tank weighs about 9 pounds including filler neck and gas cap. Arm is 110.3 inches.
I had mine loose and out so just weighed it. With the filler tube and fuel cap attached, sight gauge as well as the Moeller, weighed in at exactly 10 lbs. I was VERY liberal with the pro seal when making it also.
I weighed Van's tank a year ago with the sight glass but before the frangible bolt attachment mods. There is NO Moeller gauge and almost as much Proseal as Don used.
According to Odyssey's data sheet, the PC680 weighs 15.4 pounds. Looking at Van's RV-12 WEIGHT & BALANCE WORKSHEET, the leading edge of the wing is at 70" aft of datum. By looking at the picture, a rough estimate of the battery arm is 43". For more accuracy, measure from the leading edge of the wing to the center of the battery and subtract that distance from 70". It will help to hold a 4-foot-level vertically against the wing. You probably already thought of doing that.
As for the CG of the empty fuel tank, using the fuel CG of 110.28 is probably pretty close. If you want it more accurate, you could suspend the tank from a wire wrapped around the tank. Move the wire fore and aft until the tank has the same attitude as when installed in the plane.
Joe Gores
Thanks Don
Could also use the weight of the stock Cowl and arm
I have the Arm at 39? is this Close?
Joe, look at the image below. i added a 39" and a 49" arm to the drawing to show where they exist based on Van's drawings.
Rahul
I used that same drawing for my estimate. But I did not print it out, only measured with a ruler held up to the computer screen.Thanks
It looks like the arm on the battery is about 43? like Joe Gores said.
Is this correct?
The forward side of the behind-the-seat MID-FUSE BRACE F-1205A is approximately 94" aft of datum. I measured from there to the battery and subtracted from 94" to get 43.5 inches for the battery CG aft of datum. This is not an accurate number but just an eyeball measurement without taking the cowl off. I would wager that 43.5" is within 1/2".
Joe Gores
