In the course of the build, you're going to need to flare a bunch of lines. If possible, borrow the Imperial and the Rolo-Flair and see which you prefer, then buy yourself one of those. I've used both and got better results with the Imperial, but that's just my preference. As the others have said, make sure you get the aircraft version and not the automotive brake line version. Leaking fuel lines are not something you want to mess around with.
