Vagabond 11
Member
Is there any information from Van's on the tank sight glass?
I guess this is why we have not seen the firewall forward kit, as Van's would have even more frustrated builders if we were done with everything and still had no gas tank. I am sure glad I do not have to stand in his booth at OSH this week, I would get real tired of all the questions that I could not give good answers to.
Vern, We have four RV12 here in Ocala thats are being built E-AB who could use a welded tank if you deside to have some built. I would think the larger the order, the price will go down.
John
352 245 9954
I want something that I can have quick visual reference to. A quick turn of the head confirms that you still have fuel. With that said, why don't we use what has been in all my other E-LSA planes? A plastic tank. You don't have to build it, you don't have to seal it, and you can see right through it.
Two reasons come to mind right away.
Much heavier.
Much more expensive.
There are other complications also. How is a baffled section (as currently designed into the metal tank) that is needed to assure fuel flow at high angles of attack, to be incorporated into a rotary molded tank?
If you could do that, and then attempted to keep the tank light, it would require other (additional weight) structure around the tank to support it and help it hold its shape (remember this is not just a plastic 5 gallon fuel jug mounted in the baggage compartment).
The metal tank really is the best engineering compromise for the RV-12.
It is a rectangular box mounted INSIDE of the gas tank using existing tank rivet holes. The big advantage is that the tubes can be replaced from outside of the tank.
The tubes are inside of a 5 sided box. The existing tank side with the 3/8" holes (that you look through) forms the sixth side of the box. No glass is used. You can stick something through the sight holes and touch the tubes. It would be necessary to cut out the webs between some of the sight holes near the top and bottom to allow room to remove clamps and tubes should that ever become necessary. Perhaps Vans will find a glass replacement soon and all of our ideas will not be needed.Joe, I must be missing something. If the tubes are inside the tank, how can you replace them from outside the tank?
So, regardless of the weight and $ penalties mentioned earlier, I would like to see a plastic/fiberglass, etc., fuel tank in my RV-12. A specially made formed RV-12 tank with clear or milky finish so that I and/or my passenger could guage the level of fuel in the tank both before take off and while airborne. And how about a 24 gallon tank as long as we are 'wishing'?
This is no place to mess around and be # or $ foolish in my opinion. Let's keep it simple and if it costs more to be safe then so be it.
