Fuel Tank Sealant
wirejock
Is there a way to take this apart to get to components out without contaminating the sealant with the hardener?
Vans Flamemaster Fuel Tank Sealant
Reason is I need two or three sessions of maybe a fourth or less. I don't want to buy several tubes. I have one fresh one in the freezer.
If it's possible, I'll transfer to tiny metal paint cans
Yes.
Carefully disassemble the device and transfer the contents to clean containers that seal well. It's a bit awkward and can be messy but works. I've done it.
Caveat, I did it several years ago and this is all from memory.
Dave
A pint?
If you're willing to fork out extra $19 then that will buy a pint in a can. Any unused can be kept in the freezer for ages and may save you forking out $21 in future for another little bit.
This is by the same manufacturer as Vans stuff.
https://www.aircraftspruce.com/catalog/appages/prosealant.php
Any time I need to make a Spruce order there's always a few screws, hardware etc that can ship for the same postage. :D
Flammaster
Yes.
Dave
Thanks Dave, I will try that first.
Shoulda, woulda, coulda!
That's what I should have done. Maybe what I will end up doing! :D
