I am current researching the countersink for the AK-42H and CR3212-4-4 rivets. These rivets are used in the FWD Tank Bracket T-1205. See pages 37-02 and 37-03.
A goggle search found:
The CR3213-4-4 rivets are 100 degrees
The AK-42H both 100 and 120 degrees were specified depending on the web site
Measuring the rivet drawing in chapter 5, indicated that both are 100 degrees. The only pulled rivet shown in chapter 5 with 120 degrees is CS4-4.
I emailed Van's about this a long time ago, and sent in a picture of what I thought the CS specs should be.
I CS'd 100 degrees for the 7 cherries and 120 for the others. This should be the real answer and that's what I did, but I don't think the plans were changed. Perhaps in actual practice it doesn't matter?
