Walt Shipley
Active Member
Well I finally got around to the dreaded task of doing the latest fuel tank mod, and my worst fears were confirmed - I have a leak. It's down in the bottom, inboard front side of the tank.
I wish I could just order some pro seal and smear some over the leak on the outside, but I'm thinking the best way to do it is to remove the fuel sender plate and the mechanical gauge so I can see what I'm doing, and spread some more pro seal over the leak area.
Any one have a similar situation, and how did you fix it?
Walt
Walt
