I?m preparing to set the AD470 AD 4-5 rivets that attach the tank inboard rib forward to the Inboard end rib. I have tried every type of squeezer and rivet set in my box and with the exception of a 10in straight rivet set, nothing seems to give adequate clearance on the skin and /or the tank attach bracket assembly.
Using the 10in rivet set will come with a ? smiley risk? unless the stars align perfect.
I?ve read numerous blogs and haven?t found any compelling information on how to tackle this issue- unless you jump off the plans which would lead to other issues. There may be a rivet set with a large offset that may work, just don?t have one handy.
If I go the 10in straight route, I was going to tape up the cup section of the rivet set and put a piece of electrical tape around the outside of the factory head to reduce the smiley risk.
Any ideas would be appreciated.
![oNZ.jpg](/proxy.php?image=http%3A%2F%2Fhalie.com%2Fscale%2F40%2FoNZ.jpg&hash=fa5d8b75c5ba2b6f72e8aafd68916479)
![oN0.jpg](/proxy.php?image=http%3A%2F%2Fhalie.com%2Fscale%2F40%2FoN0.jpg&hash=091ccdc2caa13004c6caf499336fb46c)
